Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Save your own objects in the ShelfTab ?
6 REPLIES 6
560 Views, 6 Replies
Hello, community,
I modeled in Maya19 single elements which can be put together, you surely know editors of video games
e.g.: Skyrim construction editor. The dungeons are cropped in single elements "meshes"
so that they can be put together to form a room / corridor. Now I have such single elements / corridors in different shapes like X, L and T as well as simple straight corridors. Now to put these corridors together vertex by vertex, I have to set the pivot to the corresponding vertex (Key; D+V) to connect it to the next vertex of the next corridor
(Key; V).
Now this is quite cumbersome... since I always have to have a separate corridor in the scene to copy and paste.
So now my question:
Is it possible... no it is possible...
How do I get these corridors into the shelf tab / menu?
They are defined somewhere in the script?
Exactly the same as when I create a cube in the MEL that comes:
polyCube -w 1 -h 1 -d 1 -sx 1 -sy 1 -sz 1 -ax 0 1 0 -cuv 4 -ch 1;
Where are these coordinates for my self-made objects which I have named?
If I had them,
I could put them all in the Shelf Tab and select them by clicking !
Greetings
6 REPLIES 6
Hi! Construct geometry using point positions in 3d space is not simple task. You can save your models and the use import command like this:
import pymel.core as pm
pm.importFile('/path/to/your/file.ma')
 and add this command to your shelf.
Jo Genial ... something like that could work.
THANK YOU
I'll try it.
Danke
Well... it would have been nice... unfortunately, I can't do it with me.
with or without () ??
?? --> that comes with it too?
Does neither MEL nor Python...
What am I doing wrong?
It's pymel with python syntax. So it would by with ()
Tags (1)
pm.importFile(E:\SAVES Work\fly2\Gygoracdesea Desktop\biblo\lampe New2.ma)
# Error: invalid syntax #
pm.importFile('E:\SAVES Work\fly2\Gygoracdesea Desktop\biblo\lampe New2.ma')
# pymel.core : Updating pymel with pre-loaded plugins: svgFileTranslator, mayaHIK, invertShape, GamePipeline, curveWarp, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, ATFPlugin, hairPhysicalShader, cacheEvaluator, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, gameFbxExporter, VectorRender, OpenEXRLoader, lookdevKit, Unfold3D, Type, mayaCharacterization, Boss, mtoa, meshReorder, modelingToolkit, MayaMuscle, rotateHelper, matrixNodes, bifmeshio, AbcImport, autoLoader, deformerEvaluator, sceneAssembly, gpuCache, Substance, OneClick, shaderFXPlugin, objExport, bifrostshellnode, renderSetup, GPUBuiltInDeformer, ArubaTessellator, stereoCamera, quatNodes, fbxmaya #
# Error: RuntimeError: file C:\Program Files\Autodesk\Maya2019\Python\lib\site-packages\pymel\internal\pmcmds.py line 134: File not found. #
It does not work!
Sorry but you  need to learn basic syntax of Python.
Technology Administrators
