If I use euler, the rotations don't get messed up when I close and reopen, but the gimbal lock makes it way harder to get the rotation right.
Here's a video of the problem that shows what the animation looks like both before and after saving:
Sometimes it's worse than this, and if I save the messed up version and then close and reopen, the values have changed again.
I've been using 3ds Max for years, but I'm pretty new to Maya. Has anyone else experienced this issue, or can anyone tell me if there's some setting or other than I need to use to make sure this doesn't happen?
Solved by mspeer. Go to Solution.
Hi @Anonymous and welcome!
Can you attach the scene file here or via dropbox/google drive so I can take a look at it?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hey! Sorry, I thought I'd attached it. Yes, absolutely, I can do that! Thanks!
Hi!
I did 2 savings and imported them to the original file.
This is the result, there seems to be a problem with your attributes for tailPosControl.rotate:
Hi @Anonymous just checking in, did @mspeer's solution help at all?
All the best,
Sean Heasley
Hey, thanks guys!
I see there's a problem with the TailPosControl and that doubleAngle attribute. To be honest, I don't know much about scripting, at least not yet, so I don't understand the relationship between the doubleAngle attribute and Maya changing my rotation values when saving.
However, I did end up resolving the issue with a help from my animation professor.
We selected the tailPosControl, and then went to edit>keys>bake simulation, and baked it down with Smart Bake turned on and the percent set to 1. After that, the values stopped changing when saving the file.
I wish I could also tell you guys we figured out how it ended up getting messed up in the first place, but even asking around at the animation studio he works at, nobody could figure out how the problem started. Just one of those things, I guess.
Anyway, I really appreciate everyone's help!
Hi!
Glad you found a solution.
The problem is, there should be only 1 value (for each rotation axis) not 2, so "doubleangle" and not "doubleangle doubleangle".
If you duplicate the object (tailPosControl), the duplicate has only 1 value as expected.
I am not sure what caused this but i don't have the time to look deeper into this.
