Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Right-click Menu ERROR on curves
5 REPLIES 5
Zivyang
1637 Views, 5 Replies
Hi
After recent update, I got Error shows that //Error: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/uiRes.mel line 107: displayString identifier "m_dagMenuProc.kEditUVModeWarn" does not exist. does not exist.
When right-clicking the menu and try to edit the curves. Please help.
Tags (3)
5 REPLIES 5
sean.heasley
in reply to: Zivyang
Hi @Zivyang and welcome to the community!
You can try deleting your settings/preferences.
Let me know if anything changes!
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Zivyang
in reply to: sean.heasley
The issue still not been fixed after I reset Maya to default by delete prefs.
Thanks for the help.
mspeer
edit: removed
sean.heasley
in reply to: mspeer
Hi @Zivyang
It looks like something happened with your mel script that is linked to the menu when you right click.
There was a similar issue in this thread here but if that does not work you may want to do a clean uninstall and reinstall.
Steps to do a proper clean uninstall can be found here.
This is some pretty lazy tech support here...
Really?
"Delete your prefs!"
"Uninstall, reinstall!"
What's next, Uninstall windows, and reinstall it? Just get a new computer? How about switching to 3D Max?
Do I get a cookie now for providing these wonderful helpful tips?
In any case, you can do the edits if you just do everything through the menus.. which is really time consuming and defeats the purpose of the hot wheel.
C'mon Autodesk, get your stuff together. These kind of bugs are unacceptable - Everybody at my workplace has this bug specifically.
Technology Administrators
