Maya Forum
Welcome to Autodeskโ€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
RIGGING blood pressure cuff. HELP PLEASE!!
0 REPLIES 0
Message 1 of 1
249 Views, 0 Replies
HI Everybody.
I have a serious problem i've been trying to fix for some months now. I really need some help. I'm working in Maya 2016
I have this blood pressure cuff i need to rig and inflate. I need the blood pressure cuff to be able to be folded on itself. I need my rig to be dynamic so the characters hands can hold the cuff and fold it but it also needs the influences of gravity and other dynamic stuff.
I have tried rigging it with a joint chain and making that dynamic with a curve, the problem i'm getting when I use the nhair or wire deformer is a geometry twisting deformation when I try to make the geometry fold over on itself. EVERYTHING would work fine if that twist deformation did not happen. People are saying it's because I'm using a wire and after 360 degrees it rotates. I DON'T UNDERSTAND WHY THIS HAPPENS OR HOW TO FIX IT!!
I have tried making the blood pressure cuff an ncloth, however The interactive playback is very very slow, and will not playback, my polycount is not that high, I don't understand why the ncloth will not simulate, but when I use a lower poly geo, ncloth works just fine. Maybe its my iMac 8GB ram that can't hand it. HELP, but thats all I have to work with and desperately need a solution to this problem.ASAP
HELP HELP HELP, this project has me pulling out my hair! ๐Ÿ˜ž
0 REPLIES 0
Technology Administrators
