Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Retopology Issue Urgent help ?
1 REPLY 1
dong1_18
174 Views, 1 Reply
having Retopology issue the Quad draw keeps on penetrating the mesh need to know how to prevent it from happing
1 REPLY 1
hamsterHamster
in reply to: dong1_18
As you will add divisions, the mesh will assume closer resemblence to the reference mesh.
If you want offset right away, then select reference mesh's faces and do EditMesh>Transform.. drag the blue arrow, so you can "inflate" the reference a tiny little bit. Make then it Live again, select all the vertices of the retopo mesh and move a tad, so they snap to the inflated ref.
Later on, you just nullify the transformComponent translation, or select the node and hit Del.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
