Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Restore Panel Layout - save layout with file
2 REPLIES 2
magillaGuerilla
129 Views, 2 Replies
Maya does not restore layout when reopening files - incredibly tedious to manually set this up every time I open a file.
Zese settings zey do nuzzink!
Anyone got a hot tip to make Maya do what it is supposed to do?
2 REPLIES 2
Turns out you need this on to do restore the layout - perhaps this option also needs to be in the Panel config rollout
But I notice the timeline resets to 0-100 (not the saved frame range) and is not restored with the execute script node option on.
With both of these options enabled the layout still does not save or restore with the file. Good work Autodesk. Failing at the simplest things is what you do best.
