Announcements
Repositioning only one joint without any effect on the other?
Hi
I am new to Maya and just started rigging a character.
I made the foot skeleton but i just realized that i positioned my toe joint too high.
How can i reposition the toe joint without moving the ball or heel of the leg??
Please help! I really don't want to start over 😞
I have attached 2 pictures for better understanding of my issue
ray
You can move one joint without affecting its children using the D key. Select the joint you want to move, press the W key to select the move tool, then press and hold the D key and move the joint.
Hope it helps
Ray
Thanks, that was very helpful
That doesn't work. They still move the same.
manuel-thoma
I know, it's solved, but is there a way to make this work after you keyframed the bones? After I set a keyframe for one or more bones, I can't move them individually.
luisandro.garza
no you need to unbind the skin and start over
jtan61
Community Visitor
Community Visitor
This worked! Thanks so much!
