Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Report about a crash bug
2 REPLIES 2
232 Views, 2 Replies
I've found this problem a few times while using maya2023, sometimes when I stop modeling to take a sip, when I come back it tells me my software is crashing. It doesn't crash in use like other software, it usually crashes at rest. (Maybe it crashes while working on other people's computers as well, but I haven't encountered that). But on the same computer, maya2020 works fine and never had such a problem.
Here is the crash report
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x793D9D00
Fault address:  7BE1639A in D:\Maya2023\bin\Qt5Gui.dll
0001:0008539A 逻辑偏移量(有关位置,请参阅 .map 文件)
调用堆栈:
模块: D:\Maya2023\bin\Qt5Gui.dll (-export-)
位置: Qt5Gui.dllQImage::~QImage + 40 bytes
Decl: public: virtual __cdecl QImage::~QImage(void) __ptr64
位置: Qt5Gui.dllQRasterPlatformPixmap::~QRasterPlatformPixmap + 1C bytes
Decl: public: virtual __cdecl QRasterPlatformPixmap:::~QRasterPlatformPixmap(void) __ptr64
模块: D:\Maya2023\plugins\platforms\qwindows.dll (-export-)
位置:qwindows.dllqt_plugin_query_metadata + 1295 字节
位置: Qt5Gui.dllQPixmap::~QPixmap + 3E bytes
Decl: public: virtual __cdecl QPixmap::~QPixmap(void) __ptr64
位置: Qt5Gui.dllQPixmapCache::Key::operator= + 141 字节
Decl: public: class QPixmapCache::Key & __ptr64 __cdecl QPixmapCache::Key::operator=(class QPixmapCache::Key const & __ptr64) __ptr64
位置: Qt5Gui.dllQPixmapCache::totalUsed + 1CD bytes
Decl: public: static int __cdecl QPixmapCache::totalUsed(void)
位置: Qt5Gui.dllQPixmapCache::find + D7 bytes
Decl: public: static bool __cdecl QPixmapCache::find(class QString const & __ptr64,class QPixmap * __ptr64)
位置: Qt5Gui.dllQPixmapCache::setCacheLimit + 9C bytes
Decl: public: static void __cdecl QPixmapCache::setCacheLimit(int)
模块: D:\Maya2023\bin\Qt5Core.dll (-export-)
位置: Qt5Core.dllQ对象::事件 + 8D字节
Decl: public: virtual bool __cdecl QObject::event(class QEvent * __ptr64) __ptr64
模块: D:\Maya2023\bin\Qt5Widgets.dll (-export-)
位置: Qt5Widgets.dllQApplicationPrivate::notify_helper + 110 字节
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
位置: Qt5Widgets.dllQApplication::notify + 18B3 bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
模块: D:\Maya2023\bin\ExtensionLayer.dll (-export-)
位置: ExtensionLayer.dllQmayaApplication::currentSystemMouseButtons + 671 bytes
Decl: public: static class QFlags<enum Qt::MouseButton> __cdecl QmayaApplication::currentSystemMouseButtons(void)
位置: Qt5Core.dllQCore应用程序::notifyInternal2 + BA bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
位置: Qt5Core.dllQEventDispatcherWin32Private::sendTimerEvent + F9 bytes
Decl: public: void __cdecl QEventDispatcherWin32Private::sendTimerEvent(int) __ptr64
位置: Qt5Core.dllQEventDispatcherWin32::p rocessEvents + C4A bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::p rocessEvents(class QFlags<enum QEventLoop::P rocessEventsFlag>) __ptr64
模块: C:\Windows\System32\USER32.dll (-exported-)
位置: USER32.dllCallWindowProcW + 3F8 字节
位置: USER32.dllDispatchMessageW + 259 字节
位置: Qt5Core.dllQEventDispatcherWin32::p rocessEvents + 59C bytes
位置:qwindows.dllqt_plugin_query_metadata + 1F99 字节
位置: Qt5Core.dllQEventLoop::exec + 1BC bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::P rocessEventsFlag>) __ptr64
位置: Qt5Core.dllQCore应用程序::exec + 154 字节
Decl: public: static int __cdecl QCoreApplication::exec(void)
Module:  D:\Maya2023\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTapplication::start + E5 bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module:  D:\Maya2023\bin\maya.exe (-exported-)
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 1490 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 17E77 bytes
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 16FAA bytes
Module:  C:\Windows\System32\KERNEL32.DLL (-exported-)
Module:  C:\Windows\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\Administrator\AppData\Local\Temp\MayaCrashLog220716.2355.log
//version     = 23.1.0.1532
//cut            =  05/05/2022, 202205052215
//current scene = unDisclosed
//command history (most recent last):
//last tool: Move
//panel with focus: modelPanel3
//visible panels:
// modelPanel3 outlinerPanel1
//Memory usage:
// 9197.965 Mb Free Memory
// 17634.703 Mb Free Swap
// 1376.059 Mb 当前
2 REPLIES 2
nathtil
in reply to: 206079409
I'm having the same issue. The difference is this crash is happening at the start screen. I've tried everything.
in reply to: nathtil
Maya2023 was updated recently, but it seems that the problem is not solved. It crashes even with the latest version. I don't know if Autodesk developers have paid attention to this issue
