Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
repeat last tool not working with custom tool hotkeys
5 REPLIES 5
tbitters
609 Views, 5 Replies
I have created hotkeys for several of my most used tools and when I use them I would like to be able to hit the "G" key to repeat them. an example of what I would like to do. I select an edge and hit ctrl-B to bevel the edge. I press w to go back to selection and select another edge. I press G to repeat the bevel action and nothing happens. I have check marked the box next to the hotkey box to make command repeatable and add to recent command list and it doesnt seem to work either
5 REPLIES 5
hamsterHamster
in reply to: tbitters
G works when you select Bevel from any menu.
Do it once, then just gggggggggg.....
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
tbitters
if anyone has any issue with this, I was using maya 2019 and I upgraded to maya 2022. The problem no longer seems to be an issue in the newest release.
hamsterHamster
...which is unrelated, as I am using M2019 too, and have no such problem.
It is possibly your settings got corrupted.
,,,_°(O__O)°_,,,
pedram.taghdisi
Same problem here.. i m missing Y for Last Tool Used.. not working! I use latest version 2022
You were looking for G (repeat last command) ?
Im looking for Y (Last Tool used)
