Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Repeat last action is broken
2 REPLIES 2
Paremco
882 Views, 2 Replies
If I want to repeat an action by pressing 'G' but my last action was done using a hotkey it won't remember it. but it will instead repeat the last action i did that was not done by  hotkey
e.g
creates cube by clicking icon, then pressing crtl + B to create bevel, then selects next edge to bevel, Hits 'G', instead of another bevel it instead creates a cube again.
however if i do this again and i click bevel in the modelling toolkit instead of the hotkey, it then remembers it.
any ideas?
2 REPLIES 2
sean.heasley
in reply to: Paremco
Hi @Paremco and welcome to the community!
Thanks for posting this issue!
This is oddly inconsistent across hotkeys.
Your example works however if you use the Bevel tool through the menus then CTRL+E to extrude and press G it extrudes like the repeat should work.
Therefore I went ahead and logged this issue with our dev team to work on a fix!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
artur4EZV2
4 years later.
Still broken.
