AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Render stops with " [gpu] no GPU matching requirements found "
I am momentarily facing some problems in rendering in Maya 2018 with Arnold and wonder if there could be a solution given here.
The scene is being worked on a workstation with 16GB RAM and a GeForce GTX 1060 with 6GB.
Render nodes are three identical Dell Poweredge R610 with 32GB RAM and Matrox G200 onboard (8MB).
Environmetal parameter to limit to 8 MB is set on the render nodes.
I tried with backburner 2019 and with batch render and came to the same conclusion in rendering the frames.
Render failed every time with the error "[gpu] no GPU matching requirements found".
To give a complete impression I add the log file of the batch render:
R:\>"C:\Program Files\Autodesk\Maya2018\bin\render.exe" -r arnold -s 2 -e 15 -b 3 "\\RED-QUEEN\Renderdisk\endterm_300_final_folder\scenes\Rendertest_interior.mb" -proj \"//red-queen/Renderdisk/Projekte/endterm_300_final_folder\"
VP2 Warning : Forcing GPU memory limit to 512 MB. Results may differ from using detected memory limit.
Initialized VP2.0 renderer {
  Version : 2016.11.40.12. Feature Level 5.
  Adapter :
  Vendor ID: 0. Device ID :
  Driver : .
  API : DirectX V.11. Using software WARP device due to failure to obtain a hardware device
  Max texture size : 16384 * 16384.
  Max tex coords : 32
  Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
  Active stereo support available : 0
  Forced GPU Memory Limit : 512 MB.
  CPU Memory Limit: 31117.3 MB.
OpenCL evaluator is attempting to initialize OpenCL.
OpenCL evaluator encountered an unknown vendor id 0 while trying to initialize OpenCL.
Warning: line 1: Unrecognized node type for node '_aov_cryptomatte'; preserving node information during this session.
Warning: line 1: Errors have occurred while reading this scene that may result in data loss.
File read in  11.6 seconds.
Result: //red-queen/Renderdisk/Projekte/endterm_300_final_folder/scenes/Rendertest_interior.mb
00:00:00   512MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:00   512MB WARNING |  node entry "mayaFluid" is deprecated, use "MayaFluid"
00:00:29   737MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.jpg is referenced multiple times with different color spaces
00:00:33   738MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA"
00:00:33   738MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.tx is referenced multiple times with different color spaces
00:00:33   740MB ERROR   | [gpu] no GPU matching requirements found
00:00:33   740MB WARNING | aborting render pass setup:  received abort signal
[mtoa] Failed batch render
00:00:00   539MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:07   748MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.jpg is referenced multiple times with different color spaces
00:00:08   748MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA"
00:00:08   748MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.tx is referenced multiple times with different color spaces
00:00:08   748MB ERROR   | [gpu] no GPU matching requirements found
00:00:00   540MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:07   751MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA"
00:00:07   751MB ERROR   | [gpu] no GPU matching requirements found
Scene \\RED-QUEEN\Renderdisk\endterm_300_final_folder\scenes\Rendertest_interior.mb completed.
The result is identical on each of the 3 render nodes.
Anything I have to set in Maya to prevent that ?
Best regards
André
sean.heasley
Hi @Anonymous
This seems a bit unusual since Arnold is a CPU based render not GPU. That said, are all your GPU drivers up to date?
Steps to update your drivers can be found here!
@Stephen.Blair might be able to confirm as well if this is specifically an arnold issue or something else.
Stephen.Blair
That's related to the Optix Denoiser, which is GPU based.
What version of MtoA do you have? I thought this was changed in the latest.
// Stephen Blair
// Arnold Renderer Support
Dear Sean and Stephen,
thanks for responding so quickly.
My information was also that Arnold was just CPU-rendering.
The GPU drivers of the workstation I just updated 2 weeks ago fom NVIDIA 385 to the current 398.36.
Driver update for the Matrox G200 on the Dell servers are not available for Win10. So it will stay just a Microsoft Basic Display Adapter.
The Arnold Version was 3.0.0.1, so I updated that to 3.0.1.1 today on all 4 machines (which is Arnold core 5.1.1.1).
Starting the render again the error message changed to
[gpu] Nvidia cuda required
- but with the same result
C:\Users\Admin\Desktop>"C:\Program Files\Autodesk\Maya2018\bin\render.exe" -r arnold -s 1 -e 15 -b 3 "\\RED-QUEEN\Renderdisk\endterm_300_final_folder\scenes\Rendertest_interior.mb" -proj \"//red-queen/Renderdisk/Projekte/endterm_300_final_folder\"
  Adapter :
  Driver : .
  Max tex coords : 32
OpenCL evaluator failed to initialize clew.
File read in  12 seconds.
00:00:00   508MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:17   733MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.jpg is referenced multiple times with different color spaces
00:01:07   735MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA"
00:01:07   735MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.tx is referenced multiple times with different color spaces
00:01:07   737MB ERROR   | [gpu] Nvidia cuda required
00:01:07   737MB WARNING | aborting render pass setup:  received abort signal
00:00:00   530MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:16   743MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.jpg is referenced multiple times with different color spaces
00:00:32   743MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA"
00:00:32   743MB WARNING | [mtoa.autotx]  //red-queen/Renderdisk/Projekte/endterm_300_final_folder/sourceimages/WoodPlanksWorn33_NRM_3K.tx is referenced multiple times with different color spaces
00:00:32   743MB ERROR   | [gpu] Nvidia cuda required
00:00:00   533MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:06   744MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA"
00:00:06   744MB ERROR   | [gpu] Nvidia cuda required
Parameter MAYA_OGS_GPU_MEMORY_LIMIT is set to 8MB on each node.
Is it any setting in Maya that forces the batch render to use the GPU ?
Best regards
André
Ok, problem solved. I looked for the AOVs in the render settings and removed the marks for "Denoise with Optix" in the Attribute Editor.
Now all 3 nodes are running on 100%.
Thanks for your help.
Best regards
André
339023GUNLB
Community Visitor
Community Visitor
Another thing, having other software open at the same time can cause this issue. For me, it was substance painter.
