Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
reference file : attributes not saved
2 REPLIES 2
BurkhardRammner
201 Views, 2 Replies
I have a referenced file for which I changed some (array) attribute values.
Unfortunately, the changed data are not saved.
When I import the referenced file, then the data are saved...
So, what can I do about that?
Thanks!
2 REPLIES 2
Hello @BurkhardRammner,
thanks for your post. I found this information: Attribute AliasAttr on referenced nodes is not saved when opening files in Maya.
Maybe the workaround from the article (about a similar attribute) might help? If not, you are welcome to send an example file to investigate the issue further.
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Hi @patrick.schock
thanks for your trying to help me.
Issue: When you create an Alias Attribute (aliasAttr) on a referenced object. Maya will function as expected for the session. When the scene is closed and re-opened, the attribute is lost or corrupt.
Causes: AliasAttr is not a tracked edit in Maya.
Solution: This will not be fixed by the development team and the following workaround is advised:
Manually edit the .ma file to fix the setAttr command and then re-open the file.
...the solution is hilarious : /
Unfortunately, this does not help me.
Moreover, the mentioned problem is in a huge scene with lots of my own nodes.
Experience tells that:
1. it would take a lot of time to get rid of my own nodes, with a 100% chance of endless crashing
2. AD developers will not accept scenes with custom node types
