"Send to 3ds Max" is missing in Maya 2020?
patrick.proier
Message 1 of 11
patrick.proier
Hi!
i can't find in Maya 2020  Files --> send to 3ds Max?  ... instate of "send to 3ds max"  i see now "send to Unreal" and "send to Unity".
In Max 2020 the feature "send to Maya" is still there but inactive.
How can i use this feature again?
thx
Patrick
Replies (10)
Message 2 of 11
trystan.lang
Observer
Observer
Also really interested in this as we've always used it in our workflow and seems strange for it to be missing in the most recent version. If you have Max 2020 installed and Maya 2019 then the send to Maya option opens Maya 2019 but doesn't bring any geometry with it.
Message 3 of 11
DarrenP
try this fix: https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-2020-quot-send-to-quot-fix/td-p/9210785
DarrenP
Message 4 of 11
diana.yr
@patrick.proier  @trystan.lang  See if this AKN article can help on how to send objects over to 3dsMax via 2020 Maya:
https://autode.sk/2uBcQ0Z (should be same link here: https://autode.sk/3843PLM
Make sure both Maya and 3dsMax are the same 2020 versions and please let me know if this helps at all or I'll reach out to our Maya experts for more clarification or fixes as needed. Thanks!
Diana Rouge
Social Media Specialist
Message 5 of 11
patrick.proier
i have Max 2020 and Maya 2020 ...in Maya is no "send to 3ds Max" button (like in the text discription) anymore! ...instate their are send to unity and unreal buttons.
The Send to 3Ds Max did work perfectly between Max 2020 and Maya 2019!
regards,
Patrick
Message 6 of 11
Libei.Wang
Hi @patrick.proier ,
Have you tried the link posted by @DarrenP  https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-2020-quot-send-to-quot-fix/td-p/9210785
Please let us know if this is helpful.
Libei
Libei Wang
Sr QA Analyst for 3ds Max
Message 7 of 11
Sir its not working
Message 8 of 11
lupixus
for me it worked.
The problem is in the "Max2020.__._.__.syncfg" file. For unknown reason, the  "StringVersion" and the "NumericVersion" where different (2019, not 2020). Changed those values, saved the file and instantly in maya menu the option to send to max appeared.
Message 9 of 11
Go to the syncfg files, if you are using lets say maya 2020 and 3ds max 2021, in the max2021 syncfg file change the string version and numeric version to 2020 where there is 2021. Then go to maya 2020 syncfg and in the string version and numeric version replace 2020 with 2021, now the send to max and send to maya should be working correctly.
Message 10 of 11
Why should we even have to do this? We pay for a scubscription and this needs to be fixed and rolled out in the next update by Autodesk. I also cannot save the file after changing the text cause it says I need persmission even though I am using it on my own personal machine. How can I save the file to get this working?
Message 11 of 11
This supposed fix is not working for me. Any thoughts as to why?
