"Cant open ptex file" Maya 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello!
We have stepped into a strange issue that only affects one type of our renderpool. We have tried the same cmd-line on different machines. It works on all of our machine except 8 machines. And they are our most powerfull machines. They have (pretty sure) the exact same setup as our other render machines. They have the exact same version of maya installed.
This issue is driving me crazy and I cant find a good solution for it. Thats why Im trying to see if any bright minds can help me
This is the error we get:
[31m13:22:34 XGen Error: Can't find root of XGen installation. Using temp directoryC:/Users/RenderUser/AppData/Local/Temp/ [0m
XGen Version: NOT VERSIONED Build Date: Nov 30 2015 12:10:16
[34m13:22:34 XGen Stats(1): Preprocessing of P:/Project/asset/char/K//look/v001/K_K.xgen took 0.300 seconds. [0m
[34m13:22:34 XGen Stats(1): Setup for XG_RENDER_:K_rig:K|XG_RENDER_:K_rig:K_hair took 0.150 seconds. [0m
[34m13:22:39 XGen Stats(1): Setup for XG_RENDER_:K_rig:K|XG_RENDER_:K_rig:K_eyebrows took 0.000 seconds. [0m
[34m13:22:40 XGen Stats(1): Preprocessing of P:/Project/asset/char/B//look/v001/B_B.xgen took 0.321 seconds. [0m
[34m13:22:40 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_mustasje took 0.024 seconds. [0m
[34m13:22:40 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_eyebrows took 0.014 seconds. [0m
[34m13:22:40 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_suit_fur took 0.000 seconds. [0m
13:23:00 XGen Help [0m
[34m13:23:00 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_hair took 0.000 seconds. [0m
[34m13:23:00 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_hairs took 0.143 seconds. [0m
[34m13:23:29 XGen Stats(1): Preprocessing of P:/Project/asset/char/E//look/v001/E_E.xgen took 0.295 seconds. [0m
[34m13:23:29 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_suit_fur took 0.000 seconds. [0m
[34m13:23:30 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_hat_fur took 0.000 seconds. [0m
[31m13:23:30 XGen Error: Failed to find E_hat_fur/groom/orient/p_hat.ptx [0m
[31m13:23:30 XGen Error: Searched path includes:
p:/Project/xgen/collections/E/E_hat_fur/groom/orient/p_hat.ptx (Part of path doesn't exist)
${HOME}/xgen/E_hat_fur/groom/orient/p_hat.ptx (Part of path doesn't exist)
${XGEN_LOCATION}presets/E_hat_fur/groom/orient/p_hat.ptx (Part of path doesn't exist) [0m
[31m13:23:30 XGen Error: Failed to find E_hat_fur/groom/bend/p_hat.ptx [0m
p:/Project/xgen/collections/E/E_hat_fur/groom/bend/p_hat.ptx (Part of path doesn't exist)
${HOME}/xgen/E_hat_fur/groom/bend/p_hat.ptx (Part of path doesn't exist)
${XGEN_LOCATION}presets/E_hat_fur/groom/bend/p_hat.ptx (Part of path doesn't exist) [0m
[34m13:23:31 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_pants_fur took 0.000 seconds. [0m
[31m13:23:31 XGen Error: Failed to find E_pants_fur/groom/orient/p_trousers.ptx [0m
[31m13:23:31 XGen Error: Searched path includes:
p:/Project/xgen/collections/E/E_pants_fur/groom/orient/p_trousers.ptx (Part of path doesn't exist)
${HOME}/xgen/E_pants_fur/groom/orient/p_trousers.ptx (Part of path doesn't exist)
${XGEN_LOCATION}presets/E_pants_fur/groom/orient/p_trousers.ptx (Part of path doesn't exist) [0m
[31m13:23:31 XGen Error: Failed to find E_pants_fur/groom/bend/p_trousers.ptx [0m
p:/Project/xgen/collections/E/E_pants_fur/groom/bend/p_trousers.ptx (Part of path doesn't exist)
${HOME}/xgen/E_pants_fur/groom/bend/p_trousers.ptx (Part of path doesn't exist)
${XGEN_LOCATION}presets/E_pants_fur/groom/bend/p_trousers.ptx (Part of path doesn't exist) [0m
[34m13:23:32 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_hair took 0.097 seconds. [0m
[31m13:23:35 XGen Error: Failed to open p:/Project/xgen/collections/E/E_eyebrows/paintmaps/clump/p_head.ptx.
Error: Can't open ptex file: p:/Project/xgen/collections/E/E_eyebrows/paintmaps/clump/p_head.ptx
Too many open files [0m
[31m13:23:35 XGen Error: Failed to open p:/Project/xgen/collections/E/E_eyebrows/Clumping1/Maps/p_head.ptx.
Error: Can't open ptex file: p:/Project/xgen/collections/E/E_eyebrows/Clumping1/Maps/p_head.ptx
[34m13:23:35 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_eyebrows took 0.038 seconds. [0m
[31m13:23:35 XGen Error: Failed to open p:/Project/xgen/collections/E/E_eyebrows/Clumping2/Maps/p_head.ptx.
Error: Can't open ptex file: p:/Project/xgen/collections/E/E_eyebrows/Clumping2/Maps/p_head.ptx
[31m13:23:35 XGen Error: Failed to open P:/Project/asset/char/E/texture/v001/eye_brow_color.ptx.
Error: Can't open ptex file: P:/Project/asset/char/E/texture/v001/eye_brow_color.ptx
[34m13:23:35 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_face_fur took 0.000 seconds. [0m
" Error: Can't open ptex file:" and "Too many open files"
What can be the cause of this?
This is the log of a working render machine:
[31m13:23:00 XGen Error: Can't find root of XGen installation. Using temp directoryC:/Users/RenderUser/AppData/Local/Temp/ [0m
[34m13:23:01 XGen Stats(1): Preprocessing of P:/Project/asset/char/K//look/v001/K_K.xgen took 0.738 seconds. [0m
[34m13:23:01 XGen Stats(1): Setup for XG_RENDER_:K_rig:K|XG_RENDER_:K_rig:K_hair took 0.147 seconds. [0m
[34m13:23:07 XGen Stats(1): Setup for XG_RENDER_:K_rig:K|XG_RENDER_:K_rig:K_eyebrows took 0.000 seconds. [0m
[34m13:23:07 XGen Stats(1): Preprocessing of P:/Project/asset/char/B//look/v001/B_B.xgen took 0.322 seconds. [0m
[34m13:23:07 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_mustasje took 0.025 seconds. [0m
[34m13:23:08 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_eyebrows took 0.016 seconds. [0m
[34m13:23:08 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_suit_fur took 0.000 seconds. [0m
13:23:31 XGen Help [0m
[34m13:23:31 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_hair took 0.000 seconds. [0m
[34m13:23:32 XGen Stats(1): Setup for XG_RENDER_:B_rig:B|XG_RENDER_:B_rig:B_hairs took 0.140 seconds. [0m
[34m13:24:02 XGen Stats(1): Preprocessing of P:/Project/asset/char/E//look/v001/E_E.xgen took 0.611 seconds. [0m
[34m13:24:02 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_suit_fur took 0.000 seconds. [0m
[34m13:24:03 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_hat_fur took 0.000 seconds. [0m
[31m13:24:03 XGen Error: Failed to find E_hat_fur/groom/orient/p_hat.ptx [0m
[31m13:24:03 XGen Error: Searched path includes:
[31m13:24:03 XGen Error: Failed to find E_hat_fur/groom/bend/p_hat.ptx [0m
[34m13:24:04 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_pants_fur took 0.000 seconds. [0m
[31m13:24:04 XGen Error: Failed to find E_pants_fur/groom/orient/p_trousers.ptx [0m
[31m13:24:04 XGen Error: Searched path includes:
[31m13:24:04 XGen Error: Failed to find E_pants_fur/groom/bend/p_trousers.ptx [0m
[34m13:24:05 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_hair took 0.088 seconds. [0m
[34m13:24:08 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_eyebrows took 0.043 seconds. [0m
[34m13:24:09 XGen Stats(1): Setup for XG_RENDER_:E_rig:E|XG_RENDER_:E_rig:E_face_fur took 0.000 seconds. [0m
Hope to hear from you!
