Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
"cannot delete as it has locked or read-only children."
3 REPLIES 3
constantinos9S9BJ
9597 Views, 3 Replies
Cant find a fix to this online.
Purchased this Character rig and looking to delete everything (just a duplicated rig I have).
Script editor shows for a number of character controls:
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/doDelete.mel line 111: Cannot delete 'MaleFullBody:MaleFullBody_ROOTGrp' as it has locked or read-only children. //"
Any advice would be appreciated
thanks
3 REPLIES 3
There could be various reasons the nodes get locked.
If you can detect which node/s is/are locked, you can execute lockNode command (see the syntax examples at the bottom of the page).
For multiple selected nodes, try this (untested):
string $sel[] = `ls -sl` ;
for ($s in $sel) {
    lockNode -l off $s ;
 If you want to unlock entire hierarchy, then select the top node and go Select>Hierarchy before script execution.
Afterwards, should be possible to delete.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
I had this problem with Golaem nodes and the MEL script orked perfectly, thank you !
I had this problem and it was because I forgot that the model was referenced. I went to original file and the nodes deleted easily
