Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Question of modeling capabilities of maya
5 REPLIES 5
METROID0203
568 Views, 5 Replies
Is there a function, such as the Lattice modifier of 3dsmax in maya?
Tags (1)
5 REPLIES 5
marcus
in reply to: METROID0203
no,
but maybe this is what you want:
https://www.creativecrash.com/maya/script/lattice-tool
m
METROID0203
in reply to: marcus
Thank you reply. I tried to download, but there was not only a text file. Do not mll?
marcus
well, there is an instructions file.
and the "latticeTool_2.0.txt" contains the script written in MEL.
so the easiest way for you is:
1. open latticeTool_2.0.txt
2. select all the text and copy it
3. in maya go to the script editor and paste it into a mel tab
4. select all and pull it onto your shelf with middle mouse button
5. create some polygeometry
6. run the script from your shelf
m
METROID0203
in reply to: marcus
Thank you carefully. I was able to thank you !
dimitra.blagotic1
in reply to: marcus
Do you have any other script with the same function? This one is not available anymore!
