Is there a function, such as the Lattice modifier of 3dsmax in maya?
Solved by marcus. Go to Solution.
Thank you reply. I tried to download, but there was not only a text file. Do not mll?
well, there is an instructions file.
and the "latticeTool_2.0.txt" contains the script written in MEL.
so the easiest way for you is:
1. open latticeTool_2.0.txt
2. select all the text and copy it
3. in maya go to the script editor and paste it into a mel tab
4. select all and pull it onto your shelf with middle mouse button
5. create some polygeometry
6. run the script from your shelf
m
Do you have any other script with the same function? This one is not available anymore!
