Question about the interface
Hi, i have a small monitor and when i open these channel box and other on the right side, It takes up half the screen, i can manually make smaller, but if i close and open, it will open with normal size again, can i change this tho open only in small size?
Thanks.
mspeer
Hi!
This is a problem with the new Workspaces and Channel Box that is still not solved.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Workarounds:
A: Windows -> Workspaces -> Reset "Maya Classic" to Factory defaults
B) After manual resize change the current Workspace to an other preset and then back to "Maya Classic".
C) Disable "Automatically save layout changes":
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-B69DF865-D749-43C6-9FD7-BC3E454C0311
