Quad Draw faces, facing downwards
When I use quad draw on a live object, it's faces are facing downwards.
I've checked the live object and it's normals are facing outwards, which is correct.
How do I get the quad draw face to face outwards?
Any help is appreciated.
Found solution by exporting object as .obj, importing object and reversed normals.
Jay_Mack
Thank you! Years later I was having the same problem, and this solved it. I really appreciate it.
u21mcdl2030
i am facing the same issue, i exported it as obj and imported it nut when i am trying to reverse it, it's not working.
