Python commands for Arnold?
yesthatjohn
yesthatjohn
Are there Python commands to create lights in Arnold?  I found the arnold module, but I don't see any commands related to lights.  Does anyone have resources to learn how to do this stuff?  Any help appreciated.
sean.heasley
Hi @yesthatjohn and welcome to the community!
I'm curious as to why you're looking for a python command with Arnold lights.
Does manually placing the lights from the arnold drop down not work for you? When you get a chance, please come back with a bit more information so I can properly assist you!
Stephen.Blair
No, Not for creating lights in Maya.
That's actually MtoA, not Arnold, and in this case the distinction is important.
If you really want to dig into how MtoA creates the nodes in a Maya scene, you can start with C:\solidangle\mtoadeploy\2017\scripts\mtoa\ui\arnoldmenu.py
That's the code for the Arnold menu, including the Arnold > Lights menu. But it's not an API, so it's not designed for public use.
Arnold itself is a rendering library with a C++ API. And that API has Python bindings, so you can create Arnold lights using the Arnold Python api.
But that's not what happens inside Maya. Inside Maya you have the MtoA plugin creating Maya nodes (eg a locator for an area light)
// Stephen Blair
// Arnold Renderer Support
sean.heasley
Hi @yesthatjohn
I'm just checking in to see if you need more help with this. Did the suggestion that @Stephen.Blair provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
yesthatjohn
That was a big help.  Thx!  On my Centos 7 distribution I found the file you mentioned here:
/opt/solidangle/mtoa/2017/scripts/mtoa/ui
rdavidowitz
It's been a while. Have Python commands been added for the Arnold lights?
syby119
To create an area light in arnold, simply use cmds.createNode("aiAreaLight")
