purple outline in maya
huhu_2022
huhu_2022
When creating a model, a purple outline appears automatically. If you then cut the surface with a multicat, this face will not be visible. I have not found a solution to this problem anywhere
hagen.deloss
Hi @huhu_2022 ,
Appreciate you coming to the forums with your question! So to clarify, do you have "wireframe on shaded" checked on? And this only happens after using the multicut tool?
I would first suggest going into the multi-cut tool option-box and resetting it. If "wireframe on shaded" is not turned on, I'm extra curious why this display issue would happen!
Let me know if these suggestions help 😄
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
huhu_2022
Just yesterday, there was still this problem, I tried to reset all the basic settings, but it didn't help. Today (lo and behold) Maya is working as before, but thanks for the help anyway!
