proximityWrap with deformerWeights command not work
chowooseung
Message 1 of 1
chowooseung
Exporting the proximityWrap deformer weights with the deformerWeights command generates an XML file correctly.
However, attempting to reimport this file results in the error `# Error: RuntimeError: file <maya console> line 1: Nothing imported. #`.
However, the strange thing is that if I edit the proximityWrap weights and repeat the above steps, it works fine.
The difference from the first is that weight is included in xml.
This behavior seems to be distinctly different from other deformers.
No, I tested it wrong
Replies (0)
