Problems with batch rendering.
I've had recurring issues with batch rendering in Maya. Both when launching from within Maya and through command line.
The biggest annoyance is that I don't get any error messages at all. So I can never figure out why this happens. The only way I'm able to fix it is to re-install maya completely, but since it keeps coming back (and once its back it's always there untill I reinstall) I'd like to figure out why it happens in the first pace.
So, some more info:
- I'm on Windows 10, Maya 2020.2, this issue has been present since Maya 2019 on my two home machines, but never on my work computers.
- I've been very thorough when testing and made sure there's no common user errors(Project and Render settings, missing references, using default preferences, no plugins, using very basics scenes etc.). So it shouldn't be any common novice mistakes causing it.
- Regardless of renderer used this is the message in the script editor:
- // Result: Rendering with Maya Software... //
// Result: Rendering Completed. See mayaRenderLog.txt for information. /
- Whenever the batch render stops working the mayaRenderLog.txt always gives me the date, then empty logs:
8/9/2020
8/9/2020
8/9/2020
- I do have plugins installed, this time it was: Vray, Vray Scatter and PresenZ. These have never caused issues on my work machines(The work computers usually have more stuff installed than my home machines), and the batch render was working after I've installed them. Then weeks after reinstall the batch render stops working. So while it can be any of those plugins, it doesn't feel like it.
- Resetting the prefs have never solved this issue.
- I've tried adding firewall exceptions to the Render.exe.
I'd really appreciate some help on this. I would just like to be able to find the underlying issue, feels to me like it could be some system level thing (Env variables, firewall/internet settings, registry problems) but I have no idea what to look for.
I also find the Maya reinstall process to be super tedious, I can't remove it from the windows "Add or Remove Programs" control panel. I just get an error message saying "This file does not have an app associated with it for performing this action" so I have to go through this every time: https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
(This is a separate issue but if there's a fix for my uninstall problem, let me know. Is there an .exe I can run instead of going through the "Add or Remove Program" panel?)
Let me know if you have an idea, id be happy to send more info/logs if needed.
Thanks.
