Problems importing FBX groups
Message 1 of 1
Suppose I have a group called Table and another group called Chair but inside the group there are objects with the same name. When importing them Maya does not warn of duplicated objects name but instead replace the object of the first group imported and messes it. Suppose my first group was table. When importing the group Chair Maya imports it without warning and make some of the objects in the first group to turn upside down and grows bigger if you have scaled the group.
This does not happens if before import the objects inside the groups are renamed. The problem is when using obj format. Because some obj seems to be just one object and when imported they do not appear as a group but different objects.
Is there another solution to this? Could the developer put a warning message inside the FBX import plugin so this does not happen?
Replies (0)
