Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Problem with writing decimal numbers
7 REPLIES 7
Message 1 of 8
mlodymatiVDTRN
1232 Views, 7 Replies
Hi guys,
I got a problem with writing decimal numbers in the shaders options for example.
When I'm trying to write in 0.2 or any other number, and I click enter I'm getting 2.0
Hope you can help me with that, because I'm stuck  😛
Thank you!
7 REPLIES 7
Message 2 of 8
mspeer
in reply to: mlodymatiVDTRN
Hi!
That's a known limitation with the current release (Maya 2017 and Maya 2017 SP1):
Unable to manually input numerical values with a dot or comma (OS language packages: Norwegian, Russian).
Workaround: Go to the operating system's "Time & Language" and then "Region & language" and choose "Additional date, time & regional settings". In "Region", choose "Change date, time or number formats". Choose "English, United States", then restart Maya
Message 3 of 8
janne4_4
in reply to: mspeer
I don't understand how this is can be overlooked because it is such a basic and critical functionality and clearly a bug? And it's not just Norwegian and Russian OS, I'm running on Finnish OS.
Message 4 of 8
Same problem here. Seems like they haven't done anything about it for a couple of years. Offering workarounds instead of admitting (and fixing) a bug is not very customer-oriented.
Message 5 of 8
The original issue was “fixed” with a Qt custom source code change for prior Maya releases using Qt 5.6.x
for Maya 2020, the move to Qt 5.12.x
has re-introduced the Qt strict locale setting. It was missed in the testing.  A fix is being worked on
Wayne Arnold
Developer
Message 6 of 8
infoSBZHX
Has this bug been fixed yet? I'm running version 3.5.474 and i cannot use decimals. Swedish OS. Not very keen on changing OS settings.
Message 7 of 8
infoSBZHX
in reply to: warnold1
Has this bug been fixed?
Message 8 of 8
No, not fixed. Not sure, but I think the development of this software has been ended years ago.
