Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Problem with creating divisions of a face
2 REPLIES 2
540 Views, 2 Replies
I'm trying to create divisions of a face but for some reason Maya is not dividing it using quad divisions even though I have selected quad divisions. I have tried to use linear division but that isn't working. Help would be much appreciated.
2 REPLIES 2
sean.heasley
Hi @Anonymous
Generally using an automatic divisions tool after a model has been worked on isn't recommended and often wont work well like the result in your screenshot.
An easier way to do this, would be to go to Mesh Tools->Create Edge Loop Option Box. From there, you can set the amount of edges to say 6. Now when you go to add and edge loop, Maya will add 6 instead and properly distance them apart.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
in reply to: sean.heasley
Thank you so much for your help!
Technology Administrators
