Hi @Anonymous and welcome to the community!
Did you export the Alembic from another program or from Maya?
Also, is your Maya 2018 up to date?
Finally, when you get a chance can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Yeah i did export it from maya, but to be honest i haven't updated the software....For some reason sometimes it works, some times it doesn't...it's very strange. I managed to load the scene without doing something different on my behalf....
Hi @Anonymous
Hmm that is pretty unusual.
If it happens again or anything else goes wrong please let me know!
All the best,
Sean Heasley
Hello again,
I just wanted to say that i managed to update maya to the latest version. The error is still there. I cannot find a way around this since it works randomly...
I tried to create another simulation using bullet and i got the same error. Sometime the import works perfectly but most of the times i get the error above.
If you have any thoughts on it i will really appreciate it!
Thanks in advance.
Hi @Anonymous
A quick fix you could try is deleting your settings/preferences.
If that doesn't work, when you get a chance can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
All the best,
Sean Heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
