Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Problem running the product
0 REPLIES 0
Message 1 of 1
n11295805
62 Views, 0 Replies
Does anyone have any idea how to fix this problem. Also, yes, my plan does not allow me to ask a professional
Error message:
// Error: Flags must come before objects: -CloudBaseAlpha
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem".
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found.
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item.
// Warning: file: C:\Users\Cloud\OneDrive\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\Cloud\OneDrive\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\Cloud\OneDrive\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\Cloud\OneDrive\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
// AbcExport v1.0 using Alembic 1.8.3 (built Aug 3 2022 14:35:12)
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already.
import arnold
import mtoa
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
updateRenderOverride;
import mtoa.viewport;mtoa.viewport.add_controls()
# Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/autoLoadPlugin.mel line 40: TypeError: file C:\Program Files\Autodesk\Arnold\maya2023\scripts\mtoa\viewport.py line 445: 'NoneType' object is not iterable
# # C:\Program Files\Autodesk\MayaUSD\Maya2023\0.19.0\mayausd\USD\lib\python\pxr\UsdUtils\updateSchemaWithSdrNode.py:372: SyntaxWarning: "is not" with a literal. Did you mean "!="?
if sdrIdentifier is not "":
// Bifrost: Pre-loaded mayaUsdPlugin to access proper Maya USD libraries.
// Error: toolButton -q -ann $gNonSacredToolWidget;
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable.
// Loading Bifrost version 2.5.1.0-202208011913-c060626
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
// Bifrost: Loading library: usd_pack, from: Autodesk.
// Bifrost: Loading library: usdMayaTranslations, from: Autodesk.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found.
// AbcImport v1.0 using Alembic 1.8.3 (built Aug 3 2022 14:35:12)
// Error: line 1: Cannot find procedure "rebuildShowMenu".
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# Error: RuntimeError: file C:\Program Files\Autodesk\Maya2023\plug-ins\sweep\scripts\sweepMenuItems.py line 30: Error occurred during execution of MEL script
# file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/MayaUSD/Maya2023/0.19.0/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsdMenu.mel line 57: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2023/2.5.1.0/bifrost/scripts/bifrostGraphMenu.mel line 388: menu: Object 'mainCreateMenu' not found.
// Error: line 1: Cannot find procedure "openRecentFile".
currentTime 0 ;
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Curves / Surfaces" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Poly Modeling" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Sculpting" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Rigging" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Animation" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Rendering" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "FX" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "FX Caching" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Custom" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "MASH" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Motion Graphics" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "XGen" already exists.
// Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/shelf.mel line 202: The shelf "Arnold" already exists.
currentTime 0 ;
file -f -new;
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/setNamedPanelLayout.mel line 247: Cannot find procedure "updateToolbox".
// untitled
0 REPLIES 0
