Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Please Autodesk change your UI scaling for large 4k monitors
2 REPLIES 2
thandy
403 Views, 2 Replies
I have a large 43" monitor and MAYA is impossible to work with on it.Even with 200% scaling the icons are still way too small.
Im thinking they test this on small monitors and think all is good.
Its not.
Please look at how Blender does their UI scaling and follow suite.
2 REPLIES 2
hamsterHamster
in reply to: thandy
If you happen to be on Windows, then did you know, that you can modify Maya's shortcut properties?
I don't have 43" mon, two 36" instead, and the scaling is fine.
Can't comment about OSX, I believe it has something similar.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
thandy
in reply to: hamsterHamster
hello, ty for your reply .
I did that and I had to go into maya>windows>preferences> than change the UI scale down to 125% from 200% and it worked fine. TY!
