Persp Camera NaN
Persp Camera NaN
Message 1 of 48
Persp Camera NaN
I get this weird issue where after some time, my default perspective camera goes completely blank.
The geometry still shows in top/side/bottom/etc. and I can even click in the empty space of the persp and it will select the asset in outliner, but nothing shows up in persp. The only temp solution I have is to create a new persp camera everytime it does this, but after a while, it will do it again.
I want to know if there's another solution besides creating 30 something cameras.
I deleted prefs, I tried framing the assets, and I even put any number where it shoes "NaN", it nothing happens.
Anybody have suggestions?
Thank you!
(Update, it seems like the only way I can replicate the error is when I accidentally select the camera and snap its location to an object. No errors come up in the script  editor. I use the "v" tool a lot, is there any way around this?)
Accepted solutions (4)
Replies (47)
Message 41 of 48
Thanks for the info.
but reseting the transformations, and adding a small amount of the value certainly retains your viewport issue
but when I press F to focus on a praticular object, it agains goes back to the same issue with the persp camera
Message 42 of 48
mspeer
Hi!
Check Fit factor value in Preferences -> Cameras -> View Fit.
Fit factor should be >= 0.01 (default is "0.95").
You can also update Maya.
Message 43 of 48
Thanks Scott, this is the simplest and only fix that worked.
Message 44 of 48
Thank you so much for this solution. I tried all the others and none of them were working. I was afraid I'd have to spend a lot of time searching for the files so I could uninstall the whole program successfully then reinstall. You've saved a student!
Message 45 of 48
para mi funciono perfectamente
Message 46 of 48
my god, this one worked for me.
Thanks-man, I'm in a crunch and i was about to lose it.
Message 47 of 48
If the Persp Camera doesn't work or remains an error, just create a new Camera and drag it towards the persp area to replace it.
Message 48 of 48
This still helps in 2021 😄
