I'm doing an animation with non-realistic trees with paint Effects and I use modifiers a lot to make them move and transform.
But in 2019 version the modifier appears at the center of the grid and doesn't move from there. I worked with 2015 version before and it worked great. But with 2019 the modifier doesn't move from its position when I use the move tool neither change size when I use the scale tool. However, the shape of the tree do change, but it's hard to control sinnce I don't see enough what I'm doing because I have only a little dot where my tool is. So, I know where it is but I have no idea of its size.
Is there a parameter that I can change to fix it or is it a bug and there is nothing I can do?
Please help me!
Please help me!
Solved by mspeer. Go to Solution.
Hi!
This is a problem in Viewport 2.0 and happens also in Maya 2020.
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
Hi!
In Maya main menu:
Hi!
Maya 2018 shows the same behavior.
Hi!
Hi!
"I suppose it means that Autodesk doesn't find it important enough."
- Not necessarily.
It could also mean no one discovered this bug until now, so just report it.
(It's a problem since Maya 2018)
As a workaround you can switch to Maya Legacy Viewport.
Hi!
- Not necessarily.
