Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Paint Effects Modifier doesn't work properly with 2019 version
felixgvchristine
felixgvchristine
I'm doing an animation with non-realistic trees with paint Effects and I use modifiers a lot to make them move and transform.
But in 2019 version the modifier appears at the center of the grid and doesn't move from there. I worked with 2015 version before and it worked great. But with 2019 the modifier doesn't move from its position when I use the move tool neither change size when I use the scale tool. However, the shape of the tree do change, but it's hard to control sinnce I don't see enough what I'm doing because I have only a little dot where my tool is. So, I know where it is but I have no idea of its size.
Is there a parameter that I can change to fix it or is it a bug and there is nothing I can do?
Please help me!
mspeer
Hi!
This is a problem in Viewport 2.0 and happens also in Maya 2020.
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
felixgvchristine
Does 2018 also have the same bug? If not, I could uninstall 2019 and
install 2018 instead.
C
mspeer
Hi!
Maya 2018 shows the same behavior.
felixgvchristine
Thanks for the reply.
So, if this problem has not been fixed for years, I suppose it means that
Autodesk doesn't find it important enough. No hope , then...
Is there any version I could install newer than 2015 (which doesn't work
anymore with my new computer) that works properly? Because I have paid for
a 3 year subscription and it results that one of the most important tools
that I need is not working!
Any suggestion?
mspeer
Hi!
"I suppose it means that Autodesk doesn't find it important enough."
- Not necessarily.
It could also mean no one discovered this bug until now, so just report it.
(It's a problem since Maya 2018)
As a workaround you can switch to Maya Legacy Viewport.
felixgvchristine
I reported it. Thanks.
In 2019 there is no Legacy Viewport. But on the web, I found how to add it.
So yes, the modifier works well with it. There is another bug, though.
When I render a frame, or sometimes I only move the camera, the paint
effect tree disappear from the viewport. It's still there. If I render, the
tree appears in the render. But I need to go back to Viewport 2.0 to see it
back and then change again to Legacy t o work and so on.
In Maya 2015, it was doing that too.
I'll report it too.
