Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
output window
2 REPLIES 2
i-am-elmo
592 Views, 2 Replies
output window
hi
How to disable the "output window" when maya starts?
2 REPLIES 2
hamsterHamster
in reply to: i-am-elmo
If you happen to work in Windows, then you can edit Maya shortcut properties (make on Desktop if you don't have), and set its Run mode to Minimized. The Output window will be minimized, the splash screen will be visible, then Maya will open in normal window.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
zewt
In Maya 2022, just close the window.  It'll stay closed from then on until you reopen it with Window > Output Window.
In older versions of Maya, update 🙂  Or use zMayaTools:
https://zewt.github.io/zMayaTools/tool-hide-output-window.html
