Announcements
Outliner bug with shading nodes - 2017
arcon76
Message 1 of 11
arcon76
In 2017 Update 1 the Outliner lists all shading group nodes. Display > DAG objects only is checked... selecting the nodes and right click > Hide in Outliner also has no effect. This is abnormal behavior resulting in a bloated Outliner which doesn't happen in 2016.5. I have tried re-recreating the userprefs.mel to no effect, it still happens in a new scene.
Replies (10)
Message 2 of 11
ShaunBrettig7993
Yes, looks like a bug.
ATM it looks like they are doing some other work with the outliner for 2017 with the introduction of a Display > Assigned Materials command.
You should use Help > Speak Back > Report a Problem to advise the developers of the issue.
Regards
Message 3 of 11
I have same problem.
Try this way,
1.
windows > Preferences > Rendering > Perferred Render Setup System change to Legacy Render Layers
2.
Restart maya2017
3.
Outliner already solved problem.(hide shading group node) but next,
windows > Preferences > Rendering > Perferred Render Setup System change to Render Setup
4.
Restart maya2017
5.
Message 4 of 11
13freyr
Doesn`t work. Creating fresh scene not working too. Very annoying bug
Message 5 of 11
カワダチアキ
Autodesk Support
Autodesk Support
In 2017 update1, [Hide In Outliner] > [Hide] doesn't work for shader node.
This issue was reported to our development team to fix it. However if it's by design, I will input here.
Message 6 of 11
It's still happening with update2.  Is is still on the way to be fixed?
Message 7 of 11
I'm also getting all the extra nodes in the outliner, it's seems to be completely random.
One project it's fine but in another I get something like this:
Message 8 of 11
arcon76
FYI this is still broken in Update 3 so I guess the Outliner is not a priority... Maya still can't remember its window size as well lol.
Message 9 of 11
Yup still broken on 2017 update 3 cluttering the outliner... am I missing something is the outliner not something people use everyday? seems like this would be a priority ?  Its like maya thinks the shading group is a DAG node and shows it. I have seen this bug in maya for years now lol
So yeah you can delete preferences or reload scene without references etc...or try other stuff... like using a Rubber Chicken with a Pulley in the middle lol
Message 10 of 11
RFlannery1
I found this knowledge base article with a workaround for the problem: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/In-Maya-2...
(P.S. +1 for rubber chicken with a pulley in the middle.  I love that game!)
Message 11 of 11
Awesome that script worked great. Looks like Autodesk is aware of the issue as well.
Thank you so much RFLANNERY I am happy I dont have to resort to my Guybrush techniques 🙂
