Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Opening OBJ/ OSGB file in Maya, then exporting it to a format which can be opened in Revit
1 REPLY 1
17058478d
252 Views, 1 Reply
Is there a way for me to open a OBJ/ OSGB file in Maya? If I can do it, then can I export the file to a format then can be opened in Revit? I am doing a homework that being able to use a OBJ/ OSGB file I found directly will be very useful. Thank you.
1 REPLY 1
hamsterHamster
in reply to: 17058478d
You can import OBJ format and export DXF/DWG format, which can be opened in Revit.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
