Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Ocean Shader Arnold purple plane
6 REPLIES 6
siebejanssen
2891 Views, 6 Replies
Maya's ocean shader renders as a purple plane. What to do? Also getting this error: // Warning: [mtoa] [translator polymesh] ShadingGroup oceanShader1SG has no surfaceShader input.
6 REPLIES 6
sean.heasley
in reply to: siebejanssen
Hi @siebejanssen
That color means a missing shader. Most likely there's some Maya shader nodes that are not supported by MtoA, so they are dropped when the scene is exported to Arnold.
Here's the list of supported Maya shaders: https://support.solidangle.com/x/8QtkAg
I don't see the Ocean shader on there so that is most likely why you are seeing this issue. Have you tried rendering with a different renderer like Maya Hardware/Software?
sean.heasley
in reply to: sean.heasley
Hi @siebejanssen
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
sdocaig
i change the original ocean shader to Arnold ai standard shader, then it works! thank you
emmanuelkane
emmanuelkane
in reply to: sdocaig
Please how because am also facing similar issue, can you help out
emmanuelkane
