Announcements
nParticle objects cannot be hidden in Arnold
sbest58
Message 1 of 10
sbest58
When using nParticle system with Instance geometry
I can hide the original particle objects by setting Opacity to 0, but this only works in the Viewport 2 display.
When rendered in Arnold the only way to hide particles is to make them smaller and inside of the Instance geometry.
Replies (9)
Message 2 of 10
Stephen.Blair
Object Display > Visibility on the particleShape?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
sbest58
That just hides everything.
I want to render the Instance and not the original particle
Message 4 of 10
sbest58
Viewport and Arnold images
Message 5 of 10
Stephen.Blair
No it doesn't. In this example, the tori are the instances. The cards are the points.
the particleShape is exported as a points node, and the instances as ginstance nodes. And those nodes have separate visibility controls.
// Stephen Blair
Message 6 of 10
sbest58
What do you mean "It doesn't"
It certainly does on my system - see images
Message 7 of 10
sbest58
What you have not done is replay the animation - if you do that after switching off the visibility on the particles then try a render you will see absolutely nothing!
Message 8 of 10
Stephen.Blair
Ah. I made a mistake.
How about putting visibility 0 in the Arnold > User Options of the particleShape?
That worked when I played back the animation and then rendered.
There doesn't seem to be a way to avoid the export of the particles. Maybe there is, but I don't see it yet.
// Stephen Blair
Message 9 of 10
mspeer
Hi!
You are right you can't simply hide the nParticleShape, it will not be rendered/evaluated and also not dependent graphs like instances.
For your needs there are 2 other options in nParticleShape -> Object Display:
1. Intermediate Object (which still evaluates the object but doesn't display it)
2. Template (which displays wireframe in Viewport)
Message 10 of 10
sbest58
Hi Steve,
'visibility 0' works.
Cheers
Steve
