Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Non-Orthogonal Matrix support
1 REPLY 1
VansFannel
2705 Views, 1 Reply
I've just started to learn Maya 2022 and when I have tried to export this scene to Unreal:
I got the error message:
One or more objects in the scene has local axes that are not perpendicular to each other (non-orthogonal). The FBX plug-in only supports orthogonal (or perpendicular) axes and will not correctly import or export any transformations that involve non-perpendicular local axes. This can create an inaccurate appearance with the affected objects:
Head
How can I fix this error?
You can download this Maya scene here.
1 REPLY 1
brentmc
in reply to: VansFannel
This happens because you have non-uniform scaling on the child mesh and then you rotated the parent one.
Try selecting the topmost mesh and freezing the scaling.
Modify > Freeze Transformations > Options (with just Scale checked)
Brent
Brent McPherson
Principle Engineer
