Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Node that returns highest value of 2 or more inputs
15 REPLIES 15
Message 1 of 16
cerakecera
429 Views, 15 Replies
Hi im looking for a node which returns the highest value of multiple inputs.
E.g
First inputs value is 10 and second is 0, the output should be 10.
First inputs value 0 and second is 9, output should be 9 etc..
If there isnt a node like this, how would you build a connection to achieve this function?
Switched from max to maya some time ago and still learning the node editor btw 🙂
15 REPLIES 15
Message 2 of 16
hagen.deloss
in reply to: cerakecera
Hi @cerakecera
I'm not too fluent with the node editor myself, but if you aren't seeing something that works in the Math node list in the node editor, it might be that it has to be custom-scripted. Here is the list that I'm seeing in the basic shader nodes list. If you are using Arnold or PBR materials, it might be a lil different. Just curious, but why did you make the shift from 3ds Max over to Maya?
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 16
cerakecera
in reply to: hagen.deloss
Missing that in my list over here. Is that a plugin maybe?
Originally i wanted to do the task with the pose space deformation tool, but it bugs out everytime i want to use it. Maybe you could help me there instead?
Should a make a new thread or post here?
Switched because of Ziva Vfx and Ragdoll Dynamics plugins.
Message 4 of 16
sepu6
I believe those math nodes were introduced in M 2024, they might have been in 2023 but not earlier than that. So it depends on what version of Maya you have. If you need a set of math nodes for an earlier version you can try this
https://soup-dev.websitetoolbox.com/post/mayamathnodes-20180801-9809635
There might some other libraries as well
Message 5 of 16
cerakecera
in reply to: sepu6
Yes that makes sense, im on Maya 2022. Thank you for clarifying this and the link, sepu6!
_______
Sadly i have to say that im pretty dissapointed by the support above, because this could have been told me a month ago when i opened this thread. Only after a direct message to him i got a response without any solution to this simple question. The other question regarding pose space deformation tool was also ignored...
Sorry but having difficulties to comprehend this, wasted a whole month waiting.
Message 6 of 16
hagen.deloss
Hi @cerakecera ,
Sorry to disappoint, although I'm a community manager, not technical support. If you want product support, you can open a support ticket here. I haven't done 3d animation in a while, but with more clarity, I can try to assist! The forums are a place where the community can chime in to help answer questions, the Autodesk support team is mostly dedicated to customer calls and web cases created from the previous link above. If you have further questions about what support entitlements you have with your license; that can be found here
Regarding your use of the pose space deformation tool, what specifically is the issue when you use it? More details would help folks seeing this thread isolate the issue.
  • Are you currently using the plugins  Ziva Vfx and Ragdoll Dynamics, or did you switch to Maya's built-in solutions after trying to use them?
  • Have you checked the Maya 2022 documentation around the tool?
  • Any further clarity around the actual issue, is it displaying strangely, or is the deformer interacting with your rig incorrectly?
  • Lastly, have you imported this rig/character/asset from another software or version of Maya?
Hope we can help resolve the challenges you are facing 😄
Hagen Deloss
Message 7 of 16
nobody_b
if you dont have the max node from i think 2024, you can use the condition node or the floatLogic and floatCondition nodes to compare numbers
Message 8 of 16
cerakecera
Not going to argue now about support behaviour etc., instead hoping to finally get this issue solved...
As mentioned above about whether I should open a new thread regarding the pose space deformer issue or post it here, i'll just post it here for now.
The example is a default scene with just the 2 joints and the cylinder. After adding interpolator and first pose it does that deformation. No idea why, since i followed tutorial and docs walkthrough.
This is Maya 2022.3 incl Ziva and Ragdoll plugins.
Message 9 of 16
cerakecera
in reply to: nobody_b
Thanks will try those, if i still cant get this psd issue solved
Message 10 of 16
hagen.deloss
@cerakecera
Tested this on 2024 and 2022.5 without seeing that behavior, I would recommend testing the following to see if this issue persists.
  • Update your 2022 version of Maya to 2022.5, this might be an issue that was resolved in either .4 or .5.
  • I would also recommend uninstalling/unloading those plugins and testing with a "vanilla" version of the software to rule out plugins being the culprit.
here is a gif of my 2024 test, and the steps i took to test this issue.
  • drop down on far left to Rigging view
  • go to Skeleton > create bones
  • select bones first, then mesh.
  • Skin > bind skin
Then i keyframed on frame 1 and frame 20
  • Windows > animation editor > Pose Editor
  • selected the bones and created a pose
  • went to frame 20 and selected "create new pose"
  • Did not see any mesh snapping or other behavior
In the meantime, i have asked the dev team if this issue looks familar to them, and on the offhand chance they request it, would be able to send me a file-sharing link to this test scene via DM? Thanks!
Hagen Deloss
Message 11 of 16
cerakecera
Deinstalled previous version and now running a clean maya 2023.3. No plugins, only preferences.
Below a record from start to finish of the issue still persisting and the save of it.
Message 12 of 16
hagen.deloss
@cerakecera
Thanks for testing that out, now that we have ruled out the plugins, I would for sure recommend updating your 2022.3 to either update .4 or even better .5. You can get those updates from your Autodesk Account Portal. I would also recommend resetting your preferences just in case!
Any other thoughts @sepu6@nobody_b , i haven't seen an issue like this with such a simple bone setup before.
Hagen Deloss
Message 13 of 16
cerakecera
It is 2023.3
Edit: Resetting preferences didnt change anything
Message 14 of 16
hagen.deloss
@cerakecera sorry I read the version wrong!
Just to check, is this with completely fresh preferences as well? Would you be able to share the file?
I have no idea why this issue is persisting, and have messaged some colleagues in technical support, I hope they can provide some additional insight. paging @alec.andersenLP8AU and @kelly_hynes
Hagen Deloss
Message 15 of 16
cerakecera
Yes fresh prefs.
Last thing i can do here is test the tool on another machine....
Thanks so far for the help
Message 16 of 16
Hi @cerakecera@hagen.deloss
Just took a quick look at this, it looks like the 0.ma file you sent over is bound twice, which is why adjusting the arm by 90 degrees causes the skin folds in on itself. It's actually being influenced twice, so that 90 degree rotation on the joint gets doubled when it's interpreted by the skin. You can see a similar phenomenon occur if you parent one cube to another cube, select both individually, and then translate them. The child cube will race ahead while the parent cube moves linearly.
I attached a gif of what I did to your file to return to influence parity (just an unbind). My guess would be that somehow something was selected twice, or bound twice.
Hope this helps!
