Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
No "Paint Mask" button in XGen
4 REPLIES 4
broder.a
570 Views, 4 Replies
Hey all! Sorry if this is a repost, I looked around and couldn't find anything exactly the same.
I'm learning about Xgen and using Maya 2018. The tutorial I was following (And the support documents) show there being a "Paint Mask" kind of button: 0000paintIMage.png
This issue is that it's nowhere to be found. There's an Insert Expression button with a drop-down option to "Create Map" but it just gets rid of the slider and leaves only the Expression button.
Am I missing something obvious? Is there a new way this functions?
Thank so much for any help 🙂
- Austin
4 REPLIES 4
broder.a
in reply to: broder.a
Bump?
mpgruner
Same Issue here.
have you solved the issue yet? I'm having the same issue
dollsdelhi
I was also searching the solution, I am still stuck with this, please update if any solution been found
