need some help with UV's
rushingraidenart
Community Visitor
rushingraidenart
Community Visitor
Community Visitor
I have a problem with my mesh UV, I put together this mesh in zbrush and did the UV map in maya, and didn't like how blocky it looked so I smoothed out the edges of the shirt in maya and when I port over the UV map to substance painter it breaks, I have no idea what the issue could be I tried to port a different version of the shirt, I tried to give the shirt a different UV seam, it didn't work, so I genuinely have no clue what the issue might be, can someone help me out??
how the UV looks with hard edges...
how the UV looks when I smooth edges in maya.
Christian_Santoso
Have you tried repainting it with Mudbox? i havent tried Zbrush so far, but i usually used Maya + Mudbox, and it worked really well.
You probably should try it
Jr. Solutions Engineer
Autodesk AEC Building | M&E
