My View Cube escaped....
Message 1 of 14
did I something wrong?
When starting Maya 2015, there is no View Cube visible? (See attached pics)
Have I forgot something to set - or is there another reason for the missing View Cube?Smiley Mad
Thanks for any help in advance!
Best regards Smiley Happy
Replies (13)
Message 2 of 14
halfstone
The View Cube is unupported in Viewport 2.0.  It has been that way since Viewport 2.0 was introduced, but with Maya 2015 that hardware renderer became the default.  Hence the viewcube disappears.
Go to the panel menu called "Renderer", and choose "Legacy Default Viewport" and it will come back.
Message 3 of 14
thanks for your helpful answer! So my View Cube turned back again!! 🙂
Message 4 of 14
Thanks for this.  I had the same problem but now fixed.
Message 5 of 14
My view cube has escaped too, but I don't have a Render tab either so I can't switch to Legacy.  I don't have a view cube in preferences either.  Anyone have ideas?
Message 6 of 14
halfstone
The "Renderer" tab should be at the top of each window pane (Perspective, Front, Top, etc).  There should be six items there - "View", "Shading", "Lighting" "Show" "Renderer" and "Panels"
If you don't see these headings, it means your panel-specific menus are likely to be turned off.  To turn them on again, you can press the spacebar to bring up the "Hotbox".  In the center row on the right (to the right of the box labeled "Maya", is a box labeled "Hotbox Controls".
(This is the default position of the "Hotbox Controls" box; depending on how your Hotbox is configured, it may be in a different spot).
Click on this, and look at the pop-up menu that appears.  At the bottom, there should be a checkbox labeled "Window Options".
Click on the "Window Options", and a roll-out menu will have a checkbox for "Show Pane Menubars".  If this is checked, you should see the six pane menu items at the top.
As for the View Cube not being in the Preferences window - I do not have a clue as to why this might be except that maybe you're looking in the wrong place ...  see attached image #1
Message 7 of 14
These were some better ideas than I had before, but here are the looks I am seeing (attachments).  The program just does not want to give me those features.  They told me the problem was Yosemite, so I went through all the work to wipe the HD and go back to Maverick... still nothing.  My other Maverick machine is fine but I have two more like this.  Someone PLEASE tell me what is going on.
Message 8 of 14
I have the same issue (no cube), but no Legacy option to click, in fact no Renderer tab either. View, Shading, Lighting, Show Options, Panels, but no Render... and no view cube box in preferences either
Message 9 of 14
_sebastian_f
@jane.venes: your obviously using maya LT so this is maybe a limitation of the version. i never used it so i can just guess. maybe ask in the maya LT section of this forum!? one other suggestion: it seems you are a student so why don´t you download the full maya version?
Message 10 of 14
Good idea, I will look into it.
Message 11 of 14
halfstone
Sebastian is probably correct - this is the Maya LT limitation. I didn't realize this is what you were using.   My solutions were for the full version.
Message 12 of 14
I am investigating the full version, they did not offer that to us initially. I did however put the Maya 2015 LT on one of our Windows laptops and it does have the missing features. They disappeared at the same time as the Macs, but when I opened a file that had those features, they came back. I am wondering if I am missing an update or something.
Jane Venes MFA Ph.D.
Graphic Designer
Design Educator
Message 13 of 14
Thinking more, I have that LT version on a Windows laptop, and it has those features.  They disappeared at the same time I lost them on the Macs, but when I opened an older file the missing features came back.  That solution just didn't work on the Macs.  I am still waiting for a reply on the full version.  Do you have any idea where I can get customer support that will tell me whether I am supposet to have a Renderer or Legacy in Maya LT?
Message 14 of 14
This may help you
There is also a written version here http://www.cgsharenet.com/autodesk-maya-display-viewcube-quick-tutorial/
