Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
My Select Tool Cursor is a Double Circle
3 REPLIES 3
madaburnsel
4013 Views, 3 Replies
My cursor while using the select tool is a circle within a circle. I'm assuming I pressed a hotkey and I can't get out of it, tried pressing all the buttons.
If I select multiple objects it keeps them all selected. I tried googling and could not find anything. Is anyone familiar with this feature and can tell me how to turn it off?
3 REPLIES 3
Double click onto the select cursor tool in the left menue.
Reset Tool
https://linktr.ee/cg_oglu
brentmc
in reply to: madaburnsel
This is because you have enabled Drag selection mode.
Double click on the selection tool to bring up the tool settings and set the selection style back to marquee.
Note: drag selection is mainly used for components since it only selects the closest component under the cursor. This is different then marquee which selects all components inside the region - even if they are on the back of the mesh.
Drag selection can be temporarily activated by holding down the Tab shortcut key.
Brent
Brent McPherson
Principle Engineer
nadafathisayed
in reply to: brentmc
Life saver, thank you so much @brentmc
