Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Multi-Cut tool will not allowing individual cuts.
3 REPLIES 3
matthiasprince00
133 Views, 3 Replies
I have been away from modeling and re-learning workflows.
The "Split Polygon" tool has been supplanted by new Mult-Cut tool. But its behavior is bizarre when several steps into a piece of geometry.
This simple polygon has been:
• Delete by type> History
• Freeze Transformation
• Mesh > Clean up
• Face normals are correct direction
See video below.
Any insight to rectify this troublesome issue is appreciated.
Thank you,
M.Prince
3 REPLIES 3
Have you tried to export the object as obj and import it back in?
https://linktr.ee/cg_oglu
Hey Christoph,
That worked, and the geometry is now accepting cuts again.
Thanks for the tip 👍.
I'm still hoping that Autodesk will chime in on why this occurs, so I can take steps to prevent it.
This is a bug where some "bad" history is still on the mesh. Its a really hard to catch issue. And its rare.
