Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Multi-cut tool Freeze.
2 REPLIES 2
alexkonnov87
170 Views, 2 Replies
Good afternoon!
After repeated use, the  starts to work slowly. Edges appear with a delay of a few seconds, how to fix this? Maya 2022
2 REPLIES 2
brentmc
in reply to: alexkonnov87
This is likely caused by having many nodes in your construction history.
Running the following command periodically will collapse the construction history.
Edit > Delete By Type > History
Brent McPherson
Principle Engineer
alexkonnov87
Thanks for the answer!
but the larger the model, the more often you need to clean the history. At some point, you need to clear the history after several repetitions of multi-cut, this is inconvenient.
