Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
MP4 and Image Planes in Maya 2022
4 REPLIES 4
Howald111
1296 Views, 4 Replies
Before I begin converting everything to jpg sequences I thought I would ask if anyone knows why View>Image Plane>Import Movie is only importing a black frame into Maya 2022?  I have Maya 2020 still installed on my machine, so I tested it to see if I can import the same file into it....and it works perfectly (as it should). Is there a setting in 2022 that needs to be activated to import MP4 movies properly?
Thanks.
Kris.
4 REPLIES 4
kelly_hynes
in reply to: Howald111
Are you using Cached Playback?  I thought the issue might be because of this defect:
MAYA-103484 Caching : Image planes : Movies files don't playback
However, this defect, while currently fixed, was also affecting 2020 release.
Let me test and see if I can repro your issue specifically.
Kelly
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Howald111
Great, thanks Kelly.  I think I tried turning it on and off.
Cavaliere.fab
Hi...did you have any luck with this issue?
I have the exact same problem at school where I work but I didn't find any workaround if not convertinf mp4 to mov.
I might have to try again reinstalling maya but I'd like to check other solution first.
Can somebody reply to this, please?
Howald111
in reply to: Cavaliere.fab
I'm afraid it doesn't seem to work anymore.  At least for me.  I'll go into the previous version of Maya on the same computer...and it works fine.  I ended up converting my .mp4s into jpeg sequences.  This is actually faster to work with, once you go through the hassle of doing the conversation.
