Mesh Tools dropdown menu missing...
Message 1 of 16
Hi!
So I have an Educational version of Maya 2015 through my school, but for some reason my copy is missing Mesh Tools in the menu. I still have the Modeling Toolkit in the right menu, but I can't find the tool I'm currently looking for, Create Polygon Tool, in that menu.
Does anyone know how I can get my Mesh Tools back?
Alternatively, where else I can find the Create Polygon Tool.
I added a screenshot for clarity.
Thanks a lot for help!
Replies (15)
Message 2 of 16
Hey I had the same problem as you, I went under the menu set drop down menu where for you it says polygons, click that then go to customize. A window will open called the menu set editor go to edit then click restore default menu sets which should bring back the mesh tools menu. Hope it works!
Message 3 of 16
cathy_easthope
Thanks for this! I was considering a re-install...
Message 4 of 16
Brilliant!
This worked! Thank you so much!
Message 5 of 16
works for me this method also! thaaaanks a loooot!!
Message 6 of 16
This post isnt making sense to me, can you please explain more clearly please
Message 7 of 16
Clear explanation:
On the most TOP and the most LEFT corner of Maya window there is really small menu. It looks like one thin row with one word in it and has small arrow (pointing down) in it's right end.
When you click on the arrow, the menu drops down and you see a list there:
- animation
- polygons
- surfaces
Choose "polygons" for all of the nessesary MESH menus to appear.
Message 8 of 16
Thanks a lot..
Message 9 of 16
thanks man.. u solved my problem..
Message 10 of 16
If you were talking to me, then welcome 🙂
woman 😉
Message 11 of 16
Thanks for this. I was having the same problem in Maya 2016
Message 12 of 16
Did you see the image I attached?
Message 13 of 16
Yes, I found it THANK YOU!
Message 14 of 16
Totally welcome 😉
Message 15 of 16
Thank you, this worked great!
Message 16 of 16
Smiley Happy
