Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
MEL "confirmDialog" not behaving as expected
5 REPLIES 5
776 Views, 5 Replies
//Find Workspace and open confirmDialog
string $sceneDir = `workspace -q -fn`;
string $saveSceneQuery = `confirmDialog -title "Render to this Directory?"
-message $sceneDir
-button "Yes"
-button "Set Project"
-button "Cancel"
-defaultButton "Yes"
-cancelButton "Cancel"
-dismissString "Cancel"`;
//If Answer is "Yes"
if($saveSceneQuery == "Yes"){
string $getSHs[] = `fileDialog2 -ds 1 -fileFilter "*.sh"`;
I'm running Maya 2018 on OS X.
The above code is a snippet from a larger MEL script that I wrote. However, when executed it seems to open the file dialog box and close it immediately without any interaction from he user. If I comment out the confirmDialog section and simply set the $saveSceneQuery equal to "Yes", everything works as expected. The fileDialog2 box open and lets me save the .sh file. Can anyone see why that would be/confirm you are having the same issue? (Sorry that the formatting didn't copy and paste very well)
Thank you!
Tags (1)
5 REPLIES 5
sean.heasley
Hi @Anonymous
Is your 2018 up to date?
I just tried this on on 2018 with Update 5 installed and it worked as expected with the file browser opening and waiting for my input.
in reply to: sean.heasley
Thanks for testing it out for me. I'm running update 4, but I'll give 5 a try. I'm curious though, are you on a Mac or PC? If you're on a Mac, which OS are you running? I've determined that swapping the "promptDialog" command for the "confirmDialog" will give me the same issue... so I'm thinking maybe its an OS X Finder thing. I've tried on a couple macs running different OS versions and they've all given me the same error.
Thanks again
sean.heasley
Hi @Anonymous
I'm running Windows 10 on a PC so yes its possible this may be specifically down to Mac OS's.
Updating to Maya 2018 update 5 seems to have fixed the issue. Thanks!
sean.heasley
Hi @Anonymous
No problem! Glad the update solved this issue for you!
Technology Administrators
