Announcements
MEL command to set Render Settings Image Format using Arnold
jen_steinkamp
jen_steinkamp
I can change the "Maya Software Render" "Render Settings" Image Format to tif using this MEL command:
        setAttr "defaultRenderGlobals.imageFormat" 3;
This command does not work for Arnold.
I would like to do the same for defaultArnoldRenderGlobals.
Any suggestions?
Stephen.Blair
jen_steinkamp
Hi
These examples do not seem to work, I tried this MEL script, the python does not work as well:
setAttr "defaultArnoldDriver.ai_translator" -type "string" "jpeg";
// Error: line 1: setAttr: No object matches name: defaultArnoldDriver.ai_translator
Stephen.Blair
Those script commands work in a default scene with the default Arnold nodes. You can just update the commands with the names of the driver nodes in the scene.
// Stephen Blair
// Arnold Renderer Support
jen_steinkamp
I tried a default scene and resetting to default Render Settings; I also tried creating new prefs for Maya.
I am using Arnold 5.2.2.1
print( getAttr( "defaultArnolddriver.ai_translator" ) + "\n");
// Error: line 1: No object matches name: defaultArnolddriver.ai_translator
Stephen.Blair
Any suggestions?
I'm using MtoA 5.2.2.1
// Stephen Blair
jen_steinkamp
THANKS!!!!
