Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Mayatomr procedure was not found
4 REPLIES 4
2373 Views, 4 Replies
Hi everyone,
I have a problem to load a mental ray plugin for maya 2016. Similar topic are already mentioned here, but it didn't help me.
I have a correct version of MR for Maya 2016 SP6 from this site https://knowledge.autodesk.com/support/maya/downloads/caas/downloads/content/autodesk-maya-2015-serv... - so I hope this is not the reason.
If I use a checkbox "loaded" in Plug-in Manager to load mental ray, it says error "procedure could not be found".
I attached a screenshot where you can see the path to Mayatomr file and files I used for installation.
If anyone can help me to solve this probem, I would really appreciate it!
Thank you,
Jan
Tags (1)
4 REPLIES 4
mspeer
Hi!
Wrong site. Your link is for Maya 2015 and not Maya 2016.
in reply to: mspeer
yes sorry, I just copied a wrong link for the purpose of this topic. But I have installed the correct one - for 2016.
mspeer
Hi!
Maya and Mental Ray versions have to match.
If it doesn't work you might try uninstalling and re-installing one or both applications.
But first try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
in reply to: mspeer
I had to completely reinstall autodesk aplications and now it works. So thank you for your advice!
